You can tap into the wires for the radio. I think these are the colors, but check with a voltmeter or test light. Dash lights-light blue with red stripe, 12v ignition-yellow with black stripe.
I've just about got my guages installed, but I still have to pull power for the lights and 12v ignition. Where did ya'll take power for those at?
Oh, and does anyone know where the thread is for the variable resistor to control idle speed? I havent been able to find it again.
Thanks
I also have a 2000. Use the light blue with red stripe wire on your headlight switch it will be on the bottom right side of the plug on the right. It will turn your gauge lights on when you turn on your parking lights, and aslo will dim with your dimmer switch. its the wire in the back where my finger is touching
Got the EGT and boost done tonight. Works great. Now I just have to install the trans temp sender. Where did ya'll install the sender? On my L I have it drilled into the pan, but seem to remember seeing pics of one in the case. Anyone know what I'm talkin about?
