Aerostar Ford Aerostar
Stiff Powersteering?
Old Oct 3, 2007 | 05:18 PM
DCRB's Avatar
DCRB
Ok so i have a question about my 93's powersteering...
should it be very difficult to turn the wheel when i first start the car and am moving? i have no problems turning once i'm moveing, and when the car's sitting still. but when i back out of my drive way, or a parking lot at school, and turn the wheel to go, i get a "honda manual steering rack" feel (aka its semi dificult to turn the wheel). My parent's 4.0's have no problem what so ever... but mine's a 3.0 so maybe that has something to do whith it? i doubt it though.
also, my pump has been replaced with a remanufactured pump (it says so on the pump) but sounds like i have a super charger installed in my car, even when i'm driving. could the u-joints in the steering shaft be going bad? i randomly hear a poping noise, but all steering wheel buttons work, no lights come on etc.
oh and yeah there's fluid in the pump. lots of fluid. lol
last thing, there's no visual leaks
Old Oct 3, 2007 | 05:28 PM
96_4wdr's Avatar
96_4wdr
what's the pwr. steering fluid look and smell like
nice titty pink light almost sweet oil smell or
brown/black top cat pee
does it squeel like a cat going thru the fan only when turning the wheel at low speeds or all the time.
the ps belt pulley may be slipping
some years/Aero models had a pwr steering pressure sense switch that increased the engine idle rpms in low speed 0 throttle turns.
helped keep the engine from stalling out from extra load and increased ps hydraulic pressure
Old Oct 3, 2007 | 05:41 PM
DCRB's Avatar
DCRB
ummmmm the fluid is a really thin greasy nasty black color, the belt squeaks when i turn the wheel all the way and hit the end point, but the power steering pump is always whining. even when the wheel's strait. and the whine speeds up with acceleration, but does not go away when driving.
Old Oct 3, 2007 | 06:12 PM
96_4wdr's Avatar
96_4wdr
jack the front end up and put on jack stands
then test for any binding in steering
ball joints and the inner and outer tie rod ends are the usual culprits.
wife used to have a car she only let her shop touch until a tie rod broke while she was driving.
scared her so back, she let me take over service and she never went back to that shop
search the Aero forum for power steering flush and change
run 2 quarts or more of the cheap stuff thru it until it comes out titty pink, use DextronIII/Mercon, run for 50 miles or more with the cheap stuff
then do final flush with Mobil 1 ATF, get 2 qts
put a soup can over the pwr steering fill cap, they leak in water from cowl area
if howl continues it's just common with the poor design of the FoMoCo pump
add a half bottle of Lubeguard's Red or their Pwr Steering additive.
don't put any of the other off the shelf products in, all worthless and most damage pwr steering systems especially the fragile seals
pwr steering fluid should be changed every 25k miles or more often in town driving or heavy delivery
Old Oct 3, 2007 | 06:47 PM
bozzzz94's Avatar
bozzzz94
96_4wdr
titty pink? top cat pee?
You know don't you that they have sent "UP" people at Walla Walla for less than that! The only cure for you that I suggest is to watch 3 hours of tellatubbies and to do a 5 page report on how many white feathers poor ol' big bird has coming out of his head now from Sesame street.
titty pink? Really!? slap SLAP
Old Oct 3, 2007 | 09:02 PM
96_4wdr's Avatar
96_4wdr
would you take somewhere half way between Nadeshiko pink and Web color hotpink?
or more of a pastel pink
bring those pink telletubbies around here and I'll run over them with the F350 stump jumper, they can lick the diff covers as I crush their fat fuzzy pink bodies
Old Oct 3, 2007 | 09:52 PM
bozzzz94's Avatar
bozzzz94
Now do you see how easy that was? I'm so so proud of you. You're talking now like a **** kicker from the south. I can see you now, eatin' turnips, shootin' squirels out of trees, flossing your teeth =(gap between them) with a blade of grass pulled out of the grill of your F-350. Heck, with your new and improved attitude I can imagine you on Jerry Springer. Please, PLEASE don't kick my Illinois azz. I learned this from the 3rd grade. How about I trade you my bologna sandwich and chips for your snickers bar so we can be friends? Yep, Papa don't preach, I ran so far away from the flock of seagulls; this and many more will be playin' at your next bowling tourniment. You go gettum Senior Aerostar guy! You are my newest bestest buddy.
Just playin'------Respectfully Boz
ps------would you please give me my Power Rangers and my Sheera dolls back. I gave you your own smurf's set last X-mas.
Old Oct 4, 2007 | 07:24 AM
Pablo-UA's Avatar
Pablo-UA
May be o-rings and seals of r'n'p are bad. Fluid may leake inside the rack and back insede the reservouar..... Well, there is a way to check it. Put your aero to 'n' position, increase engine speed to 1500 rpm and try to turn steering wheel from lock to lock. Better??? yes - rebuild r'n'p.
But sometimes spring of reduction valve is broken ore valve is shot. Check it too.
Dealers use gauge and adapter to measure pressure in PS line when steerinh wheel is turned to lock. As I remember it is about 60 BAR for aero.
Old Oct 4, 2007 | 08:07 PM
bozzzz94's Avatar
bozzzz94
My guess is that the bearing is dry and was made to day when the after market pump was made. Go get another one. Case closed. Happy motoring.
Old Oct 4, 2007 | 11:04 PM
DCRB's Avatar
DCRB
um... ok? i'm going to change the fluid tomorow in auto shop. wierd thing happened tho: i was going to the local winchels (102nd and glissan) and when through a puddle that splashed water up on the side of my car yesterday, and right after i went through the puddle my car refused to turn left, untill i turned it off and started it again. then it would still fight me when i would turn the wheel all the way left... noticed it only cranking it all the way right this time today
Old Oct 4, 2007 | 11:17 PM
DCRB's Avatar
DCRB
oh yeah also my tie rods had recently been replaced... have paper work to prove it i believe
Old Oct 5, 2007 | 04:06 AM
96_4wdr's Avatar
96_4wdr
valves in rack probably sticking and gummy from that burnt molasses pwr steering fluid
