Help, all 4 of my power windows have stopped working. 2 rear are in 1/2 position. No leds on window rocker switches, and no power in any of the 4 windows.
Checked the following..
Fuse Relay R02, switched with a good one.. No effect.
Fuse #22, shorted
401 Power Window 30a Circuit Breaker. Ohmed it out. Shows Short when removed. Is this ok?
Is there another fuse panel in hood area I am missing? I have only investigated teh one on passenger side..
I had this same issue when painting my interior, I learned that even if the driver switches are connected and if the others are not you will not be able to operate the windows.
