Low/Varialbe Idle
Since I first bought my truck (about a year ago) it's had transmision issues. When going about 35mph-50mph, my tourque convertor would lock and unlock a couple times with my foot completly off the gas. No big deal...
However, a couple weeks ago I noticed it was doing it extremly fast and consistently. Then, when I stopped at a red light my idle dropped to 200-300rpm for a couple seconds then came back up.
It did it twice that day, then was fine for a couple weeks. (I hoped it was just bad gas or something)
Well today, the transmission did the same crap, and the idle was a little messed up. It didnt idle low like it was going to die, but it idled a bit low and erraticly.
These two issues seem to happen at the same time. They could be a coincidence I suppose. The first time it happened truck was still fairly cold. The 2nd time it was almost warmed up fully. (I rarely drive it enough to warm the engine and trans fully)
Im just not sure where to start with this one. Cna a transmission problem even cause the engine to idle low like this?
Anyway, the oil gets changed to winter weight next week. Im thinking about changing the plugs and wires to.
Any thoughs on what this could be?
Truck Info:
85' F150 302EFI
210kmiles
It sounds like you don't drive it too often running some gas line dryer will help prevent any problems from condensation in the gas tank. Cleaning the Idle air controller will cure the idle problems 99% of the time!!
Also, where exactly is the IAC? My Chiltons doesnt really mention it....
Every now and then 20,000 miles or so clean it and it won't give you any trouble!!
If you do asearch there is a article somewhere about putting in a switch to lock up the convertor on demand, if you are cruising you can make it stay locked!!
