98 2.5L valve adjustment
Old Oct 2, 2007 | 07:12 PM
dwiles's Avatar
dwiles
98 2.5L can these valves be adjusted or is the noise i hear just normal wear on the valve train?
thanks for any help
Old Oct 2, 2007 | 09:31 PM
RangerPilot's Avatar
RangerPilot
The valves on the 2.5L are non-adjustable.
How many miles?
Valvetrain noise is not normal...check for normal oil pressure (minimum 45 PSI cold start, 15 PSI hot idle), using the specified oil grade, etc.
Old Oct 4, 2007 | 10:53 AM
BSmitty's Avatar
BSmitty
Absolutely no adjustment provision from the factory, as RP said, the design employs auto-adjusters. The 2.5l, and 2.3l w/8plug head (same head) used a roller cam setup. I would guess a roller locked up on one of the camshaft followers, or an auto adjuster failed. If it hasn't run too long in this condition, you may be able to repair it by simply replacing the faulty part. If it were me, I would pull the valve cover off and inspect the valvetrain components carefully, all of them are under the cover. Good luck whatever you decide to do.
firemedic037
34
Dec 10, 2018 09:47 AM
ljstrauss
Nov 25, 2014 01:33 PM
98woody
6.7L Power Stroke Diesel
22
Sep 30, 2013 03:26 AM
98range
Oct 4, 2008 09:46 PM
98range
Jul 13, 2007 07:27 PM
