Sponsored by: Auxito
trans problem
Old Oct 2, 2007 | 05:33 PM
Ranger GT2's Avatar
Ranger GT2
trans problem
My brother has a F250 4x4 with a 4.6 (could be a 5.4 not sure) triton and auto trans. Not sure of the year but it is aleast a 97 (that body type). He said the trans wont go into reverse. Is the reverse controlled electronically also? It works fine in the forward gears. Any help would be apreciated.
Old Oct 3, 2007 | 05:55 AM
projectSHO89's Avatar
projectSHO89
Reverse is not electrically controlled. It is all hydraulic and is based on the mechanical position of the shift lever shaft.
Probably a blown clutch or hydraulic feed circuit. Any good tranny shop will be able to diagnose it.
Steve
Old Oct 3, 2007 | 02:10 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
That truck will most likely have the 351W engine in it (could also be the 302 or 460). You might have better luck asking this in the Heavy Duty forum, or the transmission forum.
