high oil pressure
Old Feb 12, 2008 | 10:24 AM
Tremclad's Avatar
Tremclad
I haven't checked the vacuum at the PCV valve yet, but I will as soon as its not so damn cold out, apparently it'll be just below freezing later this week around here. If it's a little fix like a clogged vacuum line to the PCV valve, great!
Old Feb 19, 2008 | 03:29 PM
Tremclad's Avatar
Tremclad
I pulled the PCV valve with the engine running and there's lots of vacuum there, sucked my finger right onto the end of it. Is it true that if this was a blowby issue, I'd be down on compression and therefore power?
Old Feb 19, 2008 | 05:43 PM
Piffery1's Avatar
Piffery1
If all the blowby is occuring on one cylinder then you might not feel much difference in performance other than a little roughness at idle/low speed. If all cylinders/rings are bad then you probably would suffer a noticible loss of power. I'd do a proper compression check to see whats happening.
Old Feb 20, 2008 | 07:01 AM
Tremclad's Avatar
Tremclad
Right on, I'll check the compression on each cylinder as soon as I can.
Old Feb 20, 2008 | 10:19 AM
rbaker6336's Avatar
rbaker6336
Originally Posted by Tremclad
I. Is it true that if this was a blowby issue, I'd be down on compression and therefore power?
I have an '86 F-150 I bought new with a 302,at less than 80k miles it seemed to have enough blow by to pump up tires,and I neer noticed any great power loss and didn't burn a whole lot of oil
Old Mar 29, 2008 | 05:51 PM
Tremclad's Avatar
Tremclad
I bought a compression tool and a vacuum gauge, the temperature is almost nice enough to hang out in my driveway. I took some pics today.
Old Mar 29, 2008 | 06:04 PM
Redneck1465's Avatar
Redneck1465
Wow you definately have some blowby...or oil leaking somewhere
Old Mar 29, 2008 | 06:28 PM
rbaker6336's Avatar
rbaker6336
that looks like some water mixed
Old Mar 29, 2008 | 08:52 PM
Franklin2's Avatar
Franklin2
That stuff is normal if you do not drive the engine very much, and take lots of short trips.
How long have you had this truck, and how much have you driven it? After you drive it for awhile, you "get to know" the engine, and it communicates other things to you like;
Uses a little bit of oil.
Little bit of smoke on start up
Little bit of knocking when first started.
Has high miles.
All of this, along with the blowby, is just a sign that the engine is wore out. That does not mean it's not usable, the blowby is just a product of a lot of wear in the engine. The compression test may also reveal more about the engine's health.
If the compression numbers are pretty even on all cylinders, the engine probably has some life still in it, but it's in the sunset years of it's life.
P.S. Your alternator is on the wrong side of the engine.
Old Mar 29, 2008 | 09:08 PM
rbaker6336's Avatar
rbaker6336
normal for what?? I have had a lot of engines that don't get drove much and never had milky oil without water
Old Mar 29, 2008 | 09:22 PM
boggerted's Avatar
boggerted
Uhh, i think its also serpentine belt instead of v belt
Old Mar 29, 2008 | 09:34 PM
xlman's Avatar
xlman
where the heck is that pcv hose going to?
Old Mar 29, 2008 | 10:11 PM
  #28
Franklin2's Avatar
Franklin2
Normal for an engine with a few miles on it, and not driven till it gets good and hot and can boil that stuff out. His oil doesn't look like that, it has just gathered underneath the cap on it's way out of the engine.
I believe his PCV suction line is on the passenger side going into the rear of the carb. The line you are looking at is the air intake for the system, though if he has a lot of blowby, will also be puking oil mist and water vapor. This is the line I usually run down to the frame so it will not make a mess in the engine compartment on a worn engine.
Old Mar 29, 2008 | 10:23 PM
  #29
xlman's Avatar
xlman
Ah, i see the other now.
Old Mar 31, 2008 | 11:47 AM
  #30
Tremclad's Avatar
Tremclad
Thanks guys! I was hoping the pics would help give everyone a visual.
The chassis has 136,000 miles on it. The engine is unknown, it's out of a 1978 van and I don't know when it found its way into this truck or how much mileage it did in the van. Right now it uses 2 quarts of oil in 3000 miles, but I'd say a lot of that isn't being burnt but being puked out all over. I drive around 75-100 miles everyday as I commute 40 miles each way to work.
Is the alternator being on the "wrong side" due to it being from a 1978 Econoline van?
When the engine is at normal operating temperature it will blast out some nice black smoke out the exhaust on start up. For instance, after I run into a store and come back out and start it up.
I've got to fix the torn firewall clutch master cylinder problem first this weekend, but I'll try to do the compression check as well.
Should I be looking for another engine to replace this one?
