Hello. After purchasing a 1997 Ford Explorer in really good condition, i have experienced a couple of problems. The air-con is permanenlty on, this may be due to the air seltion switch being broken. I have another switch coming, but in the mean time I would like to pull the air-con fuse. The German handbook says that M1 should be for the air-con. When I pulled it the power to the air-bag circuit was cut. I have read the thread to rectify this problem, 256 turns of the key. I am at 126! Can anyone let me know the correct fuse for the air-con?
Thanks
Knocka
To get the help you need you will want to post in the tech forums. Click on the Forums tab at the upper left and scroll over the list. I would recommend the Explorer forum or the heating and cooling forum.
