6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Regen
Old Oct 2, 2007 | 06:19 AM
50jd60's Avatar
50jd60
Question Regen
Have seen this word used before, just what does this mean....
Old Oct 2, 2007 | 06:30 AM
rob_nc's Avatar
rob_nc
All new heavy duty diesels built after January 1, 2007 must have a diesel particulate filter in the exhaust system to capture particulate matter (soot). This filter must be regenerated (regen) periodically to oxidize the soot that's been trapped. Basically, regens clean out the filter so it can collect more soot.
Old Oct 2, 2007 | 06:35 AM
Duncan10's Avatar
Duncan10
It is the process of regenerating or cleaning out of the DPF in the exhaust system. It is done by adding extra fuel to the system to burn off the soot caught in the DPF. It probably does some other computer related things because when regen occuurs the boost dropps off or if idling then rpm go up and the exhaust temp goes up also
