Suggestions?
Old Oct 2, 2007 | 01:11 AM
bobfromktown's Avatar
bobfromktown
Suggestions?
I would usually post on the Bronco forums but they don't reply as fast as you guys.
I was wondering if I should get an Optima battery I have 2 amps, 2 10'' subs and the hi speakers are powered by the 2nd amp. I'm just wondering what an Optima Battery would do for me. Thanks for your help...
Old Oct 2, 2007 | 01:16 AM
Skandocious's Avatar
Skandocious
Optima is a better quality battery for any application, but it's not magic. Of course it would help with a setup like yours but if you're experiencing power problems then you might want to upgrade to a bigger alternator and/or add some capacitors to your stereo system.
Old Oct 2, 2007 | 01:23 AM
bobfromktown
Like what is the main advantage of having an Optima over any other?
What kind of Capactior?
What kind of Altenator should I get?
Old Oct 2, 2007 | 01:27 AM
Skandocious
What are the specs on your truck?
This is a capacitor:
http://www.crutchfield.com/S-RP8K19h...acitor&tp=2614
The idea is that it basically stores power and delivers it to your components when they demand it, instead of robbing the power directly from the alternator.
Old Oct 2, 2007 | 01:37 AM
bobfromktown
1996 Bronco 351 (5.8L) Cat back Dual Exhaust, 6'' Rough Country Lift, 35'' BFG A/T, K&N Air Filter, nothing else really.
2 Memphis 10's 800w amp, 4 Alpine Speakers I don't know the watts on the Amp powering those..
Anything Else?
Old Oct 2, 2007 | 01:39 AM
Skandocious
So why do you think you need to upgrade to an Optima battery?
Old Oct 2, 2007 | 01:41 AM
bobfromktown
When i'm sitting at a red light or just sitting with my system on and my A/C the battery gague goes down when it hits and I think that the battery isn't strong enough.
Old Oct 2, 2007 | 01:49 AM
Skandocious
A capacitor will fix that.
To test your battery throw a multimeter across the studs. It should read around +14v while running and around +12v when not running.
Old Oct 2, 2007 | 01:55 AM
bobfromktown
Old Oct 2, 2007 | 01:58 AM
Skandocious
No problem buddy, good luck.
And I would test that battery and your alternator before you go throwing any parts at it. You can remove the alternator and have it tested at your local Kragen/Auto Zone/similar auto parts store.
Old Oct 2, 2007 | 09:17 AM
matt12's Avatar
matt12
http://www.crutchfield.com/S-RP8K19hJJZ8/App/Product/Item/Main.aspx?g=725&i=120PP1002T&search=capacitor&tp=2 614
The alternator actually produces power in a pulsating form it is not a steady stream of power most electronics are not affected by this However high draw are and that is where the capacitor comes in it stores the power but also smooths out the pulses. just thought i would pass that info on Matt
