Carter AFB
Old Oct 1, 2007 | 09:49 PM
kris bassett's Avatar
kris bassett
Carter AFB
I was just wondering if anyone has a good site or two about tuning a carter AFB? It is a 600 on a 390 and I live at about 5500 Feet. I am wanting to get rid of the little stumble between the primaries and secondaries.
Thanks
Kris
Old Oct 2, 2007 | 03:10 PM
BaronVonAutomatc's Avatar
BaronVonAutomatc
Download the tuning info for Performer carbs off the Edelbrock website. They're not exactly the same but close enough that the rod/jet tables should get you in the ballpark.
Old Oct 2, 2007 | 09:22 PM
kris bassett
thank you.
Kris
Old Oct 2, 2007 | 09:33 PM
kris bassett
I was also wondering??? If you took the air valve and weights out could you run the carb as a mechanical linkage setup?
Kris
Old Oct 3, 2007 | 11:54 PM
LxMan1's Avatar
LxMan1
It is mechanical. Without the air valve, it will fall flat on it's face when you open it up because there is no accelerator pump shot to the rear barrels and it will lean out severely.
