88 M5R2 conversion?
Old Oct 1, 2007 | 08:30 PM
Nascort's Avatar
Nascort
88 M5R2 conversion?
So I have bought a 88 F-250 4x4 knowing that it had a bad transmission... 5th and reverse are shot. After shopping around I found a junkyard tranny and took it home. I cleaned it up and took off the 4x2 housing, bolted on the 4x4 housing and attemped to bolt on the t-case to find out that the output shafts were different sizes. The 4x4 has much larger shaft. The junkyard wont take the tranny back and I havent found anyone to buy it. Is there a conversion kit or adapter for the smaller output shaft to mate with the t-case? Thanx for any help.
Old Oct 1, 2007 | 10:51 PM
85e150's Avatar
85e150
A 250 should have had a ZF trans, not a Mazda.
Pics of both here. If you bought a Mazda to replace a ZF, you're out of luck.
http://www.motivegear.com/tech_info/...nny_guide.html
Aug 13, 2011 10:06 AM
91 XLt 4x4
Nov 29, 2005 02:38 PM
BlueOvalDrifter88
1978 - 1996 Big Bronco
Nov 17, 2005 12:14 AM
78fordman
Sep 13, 2005 09:49 PM
BigJake86
Apr 25, 2003 12:23 PM
