Blinker Problem
Old Oct 1, 2007 | 07:19 PM
orion39's Avatar
orion39
Blinker Problem
I have a '05 5.4L F250 with a blinker problem. I posted a thread in the Superduty area earlier, but I think that this forum may be more appropriate. The problem is that when the lever is held half way up the passenger turnsignals all work fine. When the lever is pushed all the way up, only the rear light flashes and it flashes very rapidly. My battery died on Saturday afternoon and I hooked it up to a battery charger to get it started and there have been no battery problems since. Later that night is whan the blinker problem started. What may be the cause of the blinker problem and could it be related to the battery dying earlier in the day. Thanks in advance for the advice.
Old Oct 2, 2007 | 04:43 PM
Franklin2's Avatar
Franklin2
Sounds like a bad turnsignal switch, but that's not very old to be failing.
Old Oct 3, 2007 | 12:10 PM
hhott71's Avatar
hhott71
Check the BLINKER FLUID level,, J/K
2005,, should still be under warranty.
