Holley carb question
Old Jan 22, 2002 | 09:30 PM
jlasater's Avatar
jlasater
Have a Holley carb (probably 1850?) with vacuum secondaries, and when I get on the gas hard, it bogs until I let up a little, then it takes right off. Even when the engine is winding out pretty well and I floor it, I can feel the engine hesitate. Do you guys think it's just incorrect jetting on the secondaries, or is the vacuum setup on the secondaries not set right?
Old Jan 22, 2002 | 11:13 PM
proeliator's Avatar
proeliator
I just answered this question 5 days ago, and it fixed the other blokes question. You might want to search for that thread. Or, replace your center squirter with a #25 and theres a good chance your problem will be fixed. Most guys go swapping out jets and etc not knowing that heavier vehilces need more duration on their initial shot which equals a smaller squirter. First you need to id your carb. Then pull out the squirter and look at the number stamped on it. If its larger than a #25 try this fix first since its the easiest and often the problem.
Old Jan 22, 2002 | 11:40 PM
DBF's Avatar
DBF
Post Holley carb question
Jeremy,
First check the accelerator pmp adjustment, at full throttle there should be at least .015 before the arm and diaphram are bottomed out.
Before changing squirters, check to see that the fuel is coming out both sides of the nozzel and gives a positive squirt, this is btwn the venturi's, Fix this with a piece of wire or a needle, some times you have to do it a couple of times to flush the clog out. Be careful taking the squirter out not to drop the screw or the thin gasketdown the hole.
The check valve under the screw that holds the nozzle can aslo be stuck.
Jim
Old Jan 23, 2002 | 10:42 AM
thenkel2's Avatar
thenkel2
check the vacuum diaphram spring, if a really light one was put in then it would cause the same problems.
Old Jan 23, 2002 | 05:39 PM
FEina52F1's Avatar
FEina52F1
Also inside the vacuum "can" the small check ball is often discarded/lost or the track under it is open up/deepened.
Old Jan 23, 2002 | 09:40 PM
DrFord's Avatar
DrFord
hooler1
Feb 28, 2015 09:08 PM
7986F150
Feb 26, 2012 06:52 PM
57Fitzjohn
401, 477, & 534 SD Engines
19
Jun 10, 2010 09:39 PM
shakor
Nov 1, 2002 02:43 PM
