I have a 97 xlt 4.0 4x4, and i went to autozone and had them to scan for codes, they came back with po153 and po141, i changed the drivers side one, the cel went off for about 15min, or 3 starts but then came back. what should i do next. please help.
Well to start with you should have 3 O2 sensors on the rig. And if it has more then 100,000 miles on it ,it is a good idea to change all 3. As for the codes they can be caused by a vacuum leak check all of your lines and the vacuum canister, it should be in the inner fender passenger side. Follow the lines.
