2000 7.3Pwr Stroke
Old Oct 1, 2007 | 03:04 PM
Cold_Steel's Avatar
Cold_Steel
2000 7.3Pwr Stroke
Just won't start. Turns over but, just won't start any suggestion?
Old Oct 1, 2007 | 03:07 PM
MTDewX's Avatar
MTDewX
GPR or CPS maybe,
how cold is it
Old Oct 1, 2007 | 03:12 PM
Cold_Steel's Avatar
Cold_Steel
you mean temp outside? it is 89 deg
Old Oct 1, 2007 | 03:20 PM
Cold_Steel's Avatar
Cold_Steel
The truck is cold has been started for 1 day
Old Oct 1, 2007 | 03:28 PM
Cold_Steel's Avatar
Cold_Steel
where is the GPR located?
Old Oct 1, 2007 | 03:34 PM
nlemerise's Avatar
nlemerise
Here you go:
Old Oct 1, 2007 | 03:45 PM
Cold_Steel's Avatar
Cold_Steel
the diagram is great Thanks for the help . Now to check it i use a meter on the two large post?
Old Oct 1, 2007 | 04:05 PM
bdrummonds's Avatar
bdrummonds
is there any clicking in the cab under the dash, or is it turning over slower than it normally would? If so this would indicate a low battery problem. check all connections(tight, corrosion, etc...) charge batts seperatley with a good batt charger. DO NOT USE STARTING FLUID TO TRY TO GET IT TO FIRE OFF.
Old Oct 1, 2007 | 04:07 PM
Cold_Steel's Avatar
Cold_Steel
turns over great just wont start
Old Oct 1, 2007 | 04:13 PM
PETE'S_6.0PSD's Avatar
PETE'S_6.0PSD
that sounds like batteries like Brandon said, but it might be your starter, mine when went out, i had the same problem, it was turning to slow, and than it died just like bad batteries,
just somthing to check,
if you voltage on Bats drops below 11V you bats are weak, replace them,
nlemerise's Avatar
nlemerise
Unless it was real cold last night (and where you are, I doubt it) the glow plug system is not your problem...When I have those kinds of temperatures, my truck fires immediately...cold in the morning...it doesn't need glow plugs at 89 degrees. I'm betting CPS if your batteries are good.
Old Oct 1, 2007 | 04:14 PM
PETE'S_6.0PSD
so you get WTS light on the dash when you turn the key?
if not you might have bad fuel bowl heater element, that blows fuse for PCM,
keep us posted,
Old Oct 1, 2007 | 04:26 PM
Cold_Steel's Avatar
Cold_Steel
Where is the CPS located?
Old Oct 1, 2007 | 04:31 PM
nlemerise's Avatar
nlemerise
Here you go...
PETE'S_6.0PSD
go here :
http://guzzle.rbmicro.com/cps.html
