Sponsored by: Real Truck
Help Wiper motor question
Old Oct 1, 2007 | 12:32 PM
pdmracing's Avatar
pdmracing
Cool Help Wiper motor question
I have an @003 F250 SD , went to a car wash today(water ban in GA) & the drivers side wiper got stripped. Do I have too buy a new motor? The dealer says i need to, The arm is ok, but the round cerrated silver thing that the arm clips to is twirling around. Any ideas will be appreciated
Old Oct 2, 2007 | 01:20 PM
pdmracing's Avatar
pdmracing
Took it apart last nite, its a non servicable item, what a waste. I ground down the punch marks holding the round,knurled aluminum piece. It slipped off. I drilled a small hole in the notch that holds the wiper arm key in place. Tapped it, slipped it onto the shaft & then drilled a hole into the wiper motor shaft. Put a set screw in it & its good to go. Total repair time 10 minutes. No cowl removal or new motor/transmission replacement needed
Old Oct 4, 2007 | 01:48 PM
deltasoft's Avatar
deltasoft
good job bro........sometimes when you fix your own stuff is better off and u get better results than others....thats just life.....
Glad u were able to take care of it....i fix my own stuff...
Old Oct 4, 2007 | 02:01 PM
Beerstalker's Avatar
Beerstalker
Sounds like an interesting fix. You should post some pictures so people understand it better, and can use it in the future.
Good job.
