Exhust pipe question
Old Oct 1, 2007 | 10:59 AM
ANDEN's Avatar
ANDEN
I'm trying to get the final pieces put together so I can get my 89 F150 302 (5.0L) 2WD on the road.
It looks like I need to replace the pipe between the exhaust manafold and the catalytic. (not sure if it has a name)
This is mainly due to the pipe that attaches to the air pump system (EGR??) has broken off.
I'm in Orillia Ontario Canada.
Having trouble locating a source.
Any help would be appreciated.
Andy
Old Oct 1, 2007 | 12:43 PM
Conanski's Avatar
Conanski
The exhaust Y pipe and cat are all 1 piece on these trucks.. and not cheap to buy. If it's just the air injection tube that is broken off, either remove the hose and plug the exhaust, or have a muffler shop weld on a stub so you can re-attach the air line. This will likely involve removing the Y pipe from the truck because the fitting would be near impossible to weld otherwise.
Old Oct 1, 2007 | 01:43 PM
eco's Avatar
eco
For a few hundred bucks you can get a Bassani y pipe and replace the whole thing. That or yank yours and fix it.
Old Oct 1, 2007 | 02:13 PM
ANDEN's Avatar
ANDEN
Yeah that sounds about right.
And certianly explains why the rough and dirty quote from Midas was so much.
I am thinking that maybe if worst comes to worst I might try and pull the why pipe from a junk yard special.
Thanks for the reply,
I'll Check out the Bassani
