rebuilding 351W
Old Sep 30, 2007 | 02:27 PM
1982_f150's Avatar
1982_f150
rebuilding 351W
has any one done this but totally moded it out??? aftermarket everything?? if so what did you use from the original besides the block??
Old Oct 1, 2007 | 09:04 AM
Conanski's Avatar
Conanski
What do you call "totall modded out"? What are your goals? The factory rotating assembly is good for at least double the stock HP levels so there's no need for anything beyond different pistons until you get into the 4-500hp range.
Kemicalburns's Avatar
Kemicalburns
search, this has been discussed
Old Oct 1, 2007 | 10:00 AM
1982_f150's Avatar
1982_f150
well im looking to put as much hp in it as i can for my 1500 budget. annd i want it to be as light as possible..
Old Oct 1, 2007 | 10:28 AM
Kemicalburns
efi or carb, 2wd or 4wd truck?
stroking a 5.8 would give the most gains short of running a blower or nitro
Old Oct 1, 2007 | 10:36 AM
1982_f150's Avatar
1982_f150
its an 88 f150 2wd and it has a 302 efi in it right now. but i want to put in a carbed 351.
Old Oct 1, 2007 | 10:44 AM
Conanski's Avatar
Conanski
A 351 is heavier than a 302, nothing you can do about that unless you got coin for an aluminum block. For your limited budget, the best you could do is find a set of used GT40 or aluminum aftermarket heads and do a little porting yourself. Drop 10:1 pistons on the stock rotating assembly and slap on a decent carb and intake with as much cam as the motor will clear. If you get lucky with the heads it'll make 400+HP.
