1978 - 1996 Big Bronco
Shocks
Old Sep 30, 2007 | 01:27 AM
Red91XLT's Avatar
Red91XLT
Shocks
Hey guys, I'm just wondering if anybody can tell me the extended (stock) length of the shocks on a '91 Bronco XLT with the quad shock suspension? I'm in need of new shocks and I can't find OEM replacements so I was thinking about getting something identical or slightly longer than the originals, if anybody knows the measurements, I'd really appreciate it, thanks!
JD
Old Sep 30, 2007 | 06:16 AM
b4hntn's Avatar
b4hntn
I was going to suggest you go to Forums/Search but the search feature is not working for me this morning. Shocks have been discussed many times expressesing preferences but I do not remember length being mentioned. You might try the manufacture's web site. However, I do remember most only run two in the front for a better ride even if they have the quad brackets. I can't remember if they are the forward or rear of the front axle. I think I remember greystreak92 saying the quads make it ride like a bob tail truck. Just a thought unless you have heavy tires to control. Some also prefer removing the sway bar(s) for better articulation if you need it.
Old Sep 30, 2007 | 06:29 AM
Red91XLT's Avatar
Red91XLT
well, right now I've got 33x10's all around and the shocks up front, there are two per bank, and the rear shocks are both forward the axle. I was under the impression this is the "quad shock" set up, I could be wrong. I've been looking around for oem replacements, but I keep finding that autoparts stores carry rancho and skyjacker shocks of this or that length. That's okay with me, I'm just tired of my truck being lower in front than in rear due to bad shocks. Thanks though.
JD
Old Sep 30, 2007 | 06:53 AM
b4hntn's Avatar
b4hntn
Yes, if you have six shocks total with four up front then you have the "quad shocks" option.
Maybe someone has experienced going from six to four if you are interested. I was thinking of going from four to six a couple of years ago and was discouraged from doing it.
Old Sep 30, 2007 | 06:58 AM
b4hntn's Avatar
b4hntn
I don't think shocks will affect the height. The rear end comes higher unless the suspension is changed..
Old Sep 30, 2007 | 07:00 AM
Red91XLT's Avatar
Red91XLT
shocks won't affect the "lift height", but the front end will deffinetely sit lower and sag with bad/old shocks
Old Oct 1, 2007 | 11:54 AM
mprice's Avatar
mprice
Weak coils may cause the front end to sag more than when new, but the front end was always lower even when fresh from the factory. They were built like this so when the back was loaded up to the rating the truck would ride level, rather than dragging its butt.
Calvin
Old Oct 2, 2007 | 09:14 AM
Green Sales's Avatar
Green Sales
The OEM Ford shocks should still be available from your local dealer. You should check with them and verify, however the part numbers that I have found are F4TZ-18124-G for the front of axle and 5U2Z-18V124-XA for the rear of the front axle. These are the replacing part numbers to the original part numbers E7TZ-18124-G front of axle and E7TZ-18124-M rear of front axle. I hope this information helps.
Old Oct 2, 2007 | 01:06 PM
MBBFord's Avatar
MBBFord
Personaly, I don't care for OEM shocks. That is one thing I will not buy to replace on any of my trucks.
Old shocks will NOT make the front sag, that is only the coil springs. Old shocks will not stop the truck from bouncing and you get a unstable feel, expecialy when cornering.
Any shock manufacutor should have shocks to fit your truck, and they should have different lengths. Stock, 1-2" lift, 3-4", etc...
This would be a nice time to install a small lift up front, and put longer shocks(if it doesn't already have a small lift). Just to add, shocks will not affect ride height(unless it is a specialty shock designed for just that, but I don't think they make them for these trucks).
For shocks, I'd suggest Skyjacker Nitro's or Ranch RS5000s, but I'm sure anything would be better.
Old Oct 5, 2007 | 08:47 PM
Trevor1's Avatar
Trevor1
Put the 2 inch taller skyjacker coil springs on the front with the matching 2 inch longer shocks and the truck will look great. I did this on my 93 f150 4x4.
Old Oct 8, 2007 | 10:54 AM
ToughBuiltFord's Avatar
ToughBuiltFord
FTE Sponsor
Like MBBFord said, I would go with Skyjacker or Rancho shocks. Our shop carries both brands here: http://motorhaven.autoanything.com/suspension-systems/20A50472A1.aspx
