ford explorer acting weird
Old Sep 30, 2007 | 12:48 AM
AC94EXPLORER's Avatar
AC94EXPLORER
i have a 94 ford explorer but has a 1995 engine. i just noticed in the mornings from a cold start my explorer shakes and after driving it around for awhile it puts out grayish white smoke sitting at traffic lights and blows out alittle when taking off. it just looks like its grayish white color. but on the cold start up the shake goes away after its all warmed up. i havent over heated its been acting funny since i put in the thermostat cause when i bought it it had no thermostat.
Old Sep 30, 2007 | 03:56 AM
marragtop's Avatar
marragtop
Do you have any water in the oil, or water in the oil? Did all of your problems start after putting the tstat in? Shaky idle could be a vacuum line or IAC.
Old Sep 30, 2007 | 10:59 AM
aquanaut20's Avatar
aquanaut20
Or a leaking lower intake manifold gasket, are you losing any coolant??
Old Sep 30, 2007 | 11:26 PM
AC94EXPLORER
i have to add coolant every week. i have no water in the oil.
Old Oct 1, 2007 | 01:22 AM
aquanaut20's Avatar
aquanaut20
You will probably find the lower gasket corroded on the rear passenger side over the #3 cylinder. Miss fires until the plug warms up, grey smoke (coolant), wait too long and it will contaminate the O2's and the Cat, costing $$$.
About 3 hrs to do re/re, need upper/lower gasket set, rocker cover set and Hi temp RTV, (O2 compatable), good luck.
Keep us posted.......
Old Oct 1, 2007 | 02:30 AM
aquanaut20's Avatar
aquanaut20
Note: change the "O" rings on the injectors when you put it back together
Old Oct 1, 2007 | 02:56 AM
ac91725's Avatar
ac91725
i think im just gonna take it in to see exactly wrong with it im not 100 percent sure its a blown head gasket. i may just trade it in for a newer explorer. unless i can get it fixed cheap. but i doubt it.
