I have a '97 F-250 , the emergency flasher will not work , but the turn signals work ,,,, I can not find a round type flasher in the fuse box for the energency flashers , I found the one for the turn signals ....... please help
I'm looking at the owners manual and it doesn't say where it's at, but sez 15amp fuse fuse panel. I've owned this truck ten years and don't know either. I will look in a.m. and if you don't have an ans, will try to find mine(trucks out in barn).
I just looked it up in a 99 manual. It may be the same. It shows just one flasher unit for both the hazards and the turnsignals. It's mounted in a "instrument panel relay block", which is in the center of the instrument panel. Another description in the manual says it's "near" the instrument panel.
Mine is a 97 F250HD and the emergency flasher is under the dash in back of the access panel. The flasher on fuse panel is turnsignals and the one back to back with it(back side of fuse panel) is flashers.
Thanks Guys , I finally finally found it.... Merlynr you where right ,is was behind the fuse panel , back to back with the blinker flasher ,,, What a crazy place to "HIDE" it .......................
This is my first time here on this forum , won't be my last
