ABS light coming on
The edit button at the bottom of a post window goes away after a time, I think something like an hour. So we must edit within that time.
I take it that both brake lights came on AFTER you washed the engine compartment????
If you used a pressure washer to tidy things up under there, it may have forced water into places it shouldn't go, or maybe knocked some connections loose.
With both brake lights on, I'd first look to the brake master cylinder fluid level. if thats ok, then look to the brake master cylinder float & it's electrical connector. Sometimes the float will stick or otherwise act out & the system will think fluid level is low & turn the brake light on.
I think the RABS motor is mounted on the drivers side inner fender well, just in front of the brake master cylinder, at least it is on my 99. Trace the brake lines from the master cylinder, they should lead to the RABS motor.
Let us know what you find.
Anyway, I thought it was odd that both lights came on at the same time. Something common to them both maybe. I did not use a pressure washer but we did hose it down serveral times to remove years of gunk. The brakes seems to work fine and I know the person that sold me the truck would not let it go with bad brakes. I'll check the things you mentioned.
