radius arm bushings..
Old Sep 28, 2007 | 09:26 PM
quisp-n-quake's Avatar
quisp-n-quake
Do I have to remove the entire radius arm to replace the bushings?
or is there a way to pull the arm out of the socket enough to slide on the new bushings?
Old Sep 28, 2007 | 09:55 PM
handsomerob's Avatar
handsomerob
gotta drop the Radius arm mounts or remove the arms completely, I just replaced my mounts and bushings cause the old mounts where cracked.
Old Sep 28, 2007 | 09:56 PM
radialarm's Avatar
radialarm
You can't pull it out far enough to remove the bushings. You either have to remove the bracket or the axle bolt. When the search engine comes back up search for this topic, I explaned this to a guy about a month ago.
