KeyPad????
Old Sep 28, 2007 | 07:24 PM
Beaus Truck's Avatar
Beaus Truck
KeyPad????
Im looking to put a keypadon my door like some of the f150s have stock. I found a used handle assembly with the keypad and the wire harness for sale. Will That plug into my 07 f150 that just has a regular handle?????
Thanks
Old Sep 28, 2007 | 07:36 PM
black04lariat's Avatar
black04lariat
I think you will need to get the computer re-programed to recognize it..
I believe I remember reading that somewhere.
Old Sep 28, 2007 | 09:23 PM
soxfan81's Avatar
soxfan81
did your truck come with a keyless entry code? Mine came with the code and no keyless entry. I gave my vin to yk2 ford parts and they told me it would work. I posted all the info on what I did when the search is enabled again I will post it for you
Old Sep 28, 2007 | 10:13 PM
Beaus Truck
Thanks I will keep looking and im not sure that i have a code where would i find that info.
Thanks
Old Sep 28, 2007 | 10:24 PM
soxfan81's Avatar
soxfan81
mine came on a credit card sized card and it says keyless entry code and a 5 digit pin. Did your truck come with power windows and doors?
Old Sep 29, 2007 | 07:48 AM
wlgoble's Avatar
wlgoble
My XLT did not come with a keypad, but it was pre wired for one. I just plugged it in and punched in the code from my card and it works. If you have the plastic code card in the owners manual case then that is a good indicator that it might work. If your truck is an XL or does not have power locks then you may have a diffenrent wiring harness and therefore may not be able to add one. If you take your door panel off you can see the plug in there, its round with four pins and gray and green in color. It will be about 10 inches below the where the door lock portrudes out of the top of the door panel. Even if you have this plug I wont guarentee that your computer is capable of this feature.
I know for a fact that if you have an XLT and the plastic code card, the odds are very good that doing this is just plug and play. On the XL you may just be out of luck. Sorry.
Old Sep 30, 2007 | 05:11 AM
yellowboy's Avatar
yellowboy
Ford used to sell a stick on keypad (wireless) that you could program to work, but when I tried to buy one for my Expedition 3 dealers told me they are no longer available. I wonder if any aftermarkets are available ?
Old Sep 30, 2007 | 02:00 PM
pilot10's Avatar
pilot10
I saw the stick-on keypad advertised last month for $99 in a Ford mailer. Put one on the wife's Tribute earlier this year.
If you can get the keypad in the door handle for a comparable price I would go that route. The stick-on pad will stick out just a little bit where as the keypad in handle will look cleaner.
Old Sep 30, 2007 | 05:27 PM
DaMole's Avatar
DaMole
Here is the stick-on one. http://www.troyfordaccessories.com/product/FordTruckAccessories/FordTrucks/F150/keyless-entry-keypad/FordKeylessEntryKeypad.aspx
I have been thinking about putting that on mine.
Old Oct 1, 2007 | 04:16 AM
yellowboy's Avatar
yellowboy
Thanks, don't know whey they told me it's no longer available.
Old Oct 1, 2007 | 09:33 AM
DaMole's Avatar
DaMole
I thought it was no longer available also. It is a pain in the rear to find it online. You have to type in just the correct words in the search engine.
Old Oct 1, 2007 | 01:10 PM
Quack Addict's Avatar
Quack Addict
A buddy of mine put the stick-on pad on his '03 SCREW and it worked fine. He got it at our local dealer for less than $100. It was a 15 minute job to completion. The pad was in a display case in the parts dept.
Good luck. I have the keypad on my '06 SCREW and use it daily. I hate having keys with me in the woods, swamps or on the boat to lose.
Mike Aka Quack Addict
'06 SCREW FX4
Old Oct 3, 2007 | 12:42 PM
ERIE_ONE's Avatar
ERIE_ONE
I got one for mine through the dealer. Pretty sure they are on fords site too. Works good so far.
Old Oct 4, 2007 | 08:10 AM
Corey872's Avatar
Corey872
'06 SCREW FX4
AMEN to that!!
