435 4-speed????
Old Sep 28, 2007 | 05:16 PM
polky's Avatar
polky
435 4-speed????
Is A 435 The Same Trans As A Dodge 435? Beside The Bell And Tail Are The Bolt Pattern Front And Back The Same On All 435 Trans?
Old Sep 28, 2007 | 06:55 PM
77300i6's Avatar
77300i6
Hi Polky
I believe they are the same tranny as New Process (now New Venture) is the company that built the tranny.
I'm not a 100% on this, but I think they are the same except for the bellhousing, tailshaft, and perhaps the ratios.
I've had a '77 & '78 F150 and both had the NP435-very good tranny and practically bulletproof.
Old Sep 30, 2007 | 06:11 PM
flareside_thunder's Avatar
flareside_thunder
Damn good tranny as a matter of fact and one thing that makes them bullit proof is the cast iron cases....the dodges and fords had pretty much identical ones and chevy even had a few but not too many......
Old Sep 30, 2007 | 06:40 PM
polky's Avatar
polky
My Dodge And Bronco Both Have 435, And Just Wandering If I Find A 435 From Ford, If It Could Go In My Dodge. Dodge Trans Is Going And Need To Find One.
Old Sep 30, 2007 | 09:04 PM
flareside_thunder
I think the biggest obstacle would be finding the output shaft the right spline and finding both the output and input shafts the right lengths for what you need.....your ford has what?an NP205?and that PW probly has a NP203 right?it might all be slammin n jammin......sorry I'm not more insightful.....but those would be the only differences I could think of...unless they changed the way the bellhousing bolts up to the casing.
Old Oct 1, 2007 | 06:39 AM
polky's Avatar
polky
THAT'S THE QUESTION AT HAND. DODGE 435 TRANS WENT FROM EARLY 70'S TO I THINK 85. THE 203 TRANSFER WAS 77-79 ONLY, THE REST WAS 205 AND 208. I DON'T WANT FULL TIME, SWITCHED MY DODGE FULL TIME AXLES FOR CHEVY 3/4 TON PART-TIME. NOW NEED TO DO TRANSFER CASE SWAP. AND TRANS IS PRETTY BAD SHAPE.
Old Oct 1, 2007 | 07:57 AM
77300i6's Avatar
77300i6
Have you thought about just rebuilding the tranny? IIRC, I once priced and overhaul kit for a NP435 tranny at around $200 -$300. This was for the gaskets and synchros and stuff like that. Things like the lay shaft and other gear assemblies was more.
Also, if you want a NP205 (best T-case IMO), Ford, Dodge, and Chevy all used them. I would think they are all the same except for the spline counts and U-joints. I would think that if you found one other than a dodge, you could just get the parts necessary to swap over to the dodge stuff.
Old Oct 1, 2007 | 05:38 PM
flareside_thunder
I second that and manuals aren't too difficult at all to rebuild...alot easier than an automatic that's for sure....a 205 is the best as far as I'm concerned...and if you can get your hands on a gear to gear instead of the chain driven...better off....those ain't too shabby to rebuild either and should be pretty decent on price....
Old Oct 1, 2007 | 07:23 PM
polky's Avatar
polky
I'm Pretty Mechanical, But Never Rebuilt A Trans Before. Is It Easy??
Old Oct 2, 2007 | 07:52 AM
77300i6's Avatar
77300i6
I never built one before either. I would think that if you have instructions and all the proper tools, you should be able to do it. Same with the 205.
If you do decide to rebuild it yourself, take plenty of pictures and notes during disassembly. You will thank yourself when you reassemble it later.
