headlight
Old Sep 28, 2007 | 04:31 PM
Little Louie's Avatar
Little Louie
headlight
I own a 1993 Ranger. I have noticied that my passenger side headlight is somewhat yellow and has moisture inside. Now I am using a Permatex product to get rid of the yellowing on the outside, but the inside of the passenger side headlight (capsule) has a piece of the bulb that is loose and moving around. So I have been trying to disassemble the capsule with no luck. I see that there are two(2) screws that fasten the capsule but when I try and use a phillips head screw driver nothing happens when I turn it; in fact I can only turn the driver about a 1/32 of an inch. Also, I notice that there are clips on the stud but they seem to be fastened permantly to the inner frame. If anyone has any suggestions or solutions to this problem I would be greatly appreciative. Thanx Dave
PS. my email address is xbubbax@grantsburgtelcom.net
Old Oct 15, 2007 | 07:58 PM
amish77's Avatar
amish77
Isn't the bulb simply rotated in from the back of the housing? Trace the wires and see 'cause I think that's how a lot of these work.
