Short Circuit
Doug
Since the radio is effected, the first question it "Is it an aftermarket radio"? If so, check the wiring to and around the radio. Pinched wires or sloppy installation is a very common problem with aftermarket sound systems (or any other add ons, like alarm systems, remote start, etc). Aftermarket items are always the first suspect when fuses blow repeatedly.
Cigarette lighter elements or foreign objects in the sockets are a close second if they are on the effected circuit. (Why do small children equate lighter sockets with coin slots?)
Just a thought: You mention the dome light. I recall seeing a lot of shorts in early\mid-90's Ford dome lights that had built in map lights. If your Aero has a front dome light with switches for map lighting, remove and disconnect it. See if that helps.
If the radio is OEM, and\or the wiring to any aftermarket addons checks out good, check the owners manual diagram and see what items are supplied power through Fuse #6.
Using the "light bulb across the fuse socket" trick that ken1mod mentioned, remove and disconnect each component until the short disappears.
Use an #1156, or either half of an #1157 bulb. (both are very common tail light\turn signal bulbs) A low current bulb, like a #194 (dash lights) can light up due to normal current draw in the circuit and send you chasing your tail. Many standard 12 volt test lights won't work well either. The few mils of current from the PCM or radio memory circuit will make them light.
If you disconnect everything on that circuit and still have a short, it's time to seek help.
if so, check the wire that runs thru the sun visor bracket to power the lights.
i had this exact same problem in my aero, and this was the culprit.
When I pulled the radio, there was a pair of speakers wired but the wires were bare and no wire nuts on them. I capped these off. However the "blue wire" splice bothered me. Since I am not going to use any other stereo equipment in the back I tried to pull the blue wire out. It relatively easily snapped. I clipped it off near the splice and capped it off.
So far, this seems to have fixed the problem.
We shall see.
