Backing up a trailer?
Old Oct 3, 2007 | 02:20 PM
  #31
mudmaker's Avatar
mudmaker
I guess it has never been an issue for me. why not just turn your gain down when you're backing if you're worried about it.
Old Oct 3, 2007 | 02:31 PM
  #32
thorseshoeing's Avatar
thorseshoeing
decadent and depraved
Originally Posted by [left
mudmaker[/left]
]I guess it has never been an issue for me. why not just turn your gain down when you're backing if you're worried about it.
Same here...if your trailer is braking that hard it's probably set too high anyway...
Tim
Old Oct 3, 2007 | 03:04 PM
  #33
Ironhorse7's Avatar
Ironhorse7
Usquequaque fossor!
Originally Posted by thorseshoeing
Braccae illae virides *** subucula rosea et tunica Caledonia-quam elenganter concinnatur!
Vah! Denuone Latine loquebar? Me ineptum. Interdum modo elabitur
Old Oct 4, 2007 | 09:54 AM
  #34
stormyrider's Avatar
stormyrider
Maybe oit is the trailer I tow, Horsetrailer with living quarters, a lot heaivier then a big camper and I have to run the brake gain higher to get the braking action for the weight. Everyone I know with this type of rig has the same issue and corrects it the same way, 4 low, don't lock the hubs as 4 x 4 traction is not neaded and we all run manual locking hubs, pull the plug on the trailer while backing into our spots. Never needed lights from the trailer when backing it as it has always been light out.
Old Oct 4, 2007 | 10:00 AM
  #35
mudmaker's Avatar
mudmaker
That is honestly the first time I have ever heard of using 4 low for backing unless you didnt have enough power to back up in high range. Even when I hauled cars grossing 42k I never had to use 4low. And the only time I ever pull the plug backing is when I put my boat in the water.
Old Oct 4, 2007 | 10:05 AM
  #36
MisterCMK's Avatar
MisterCMK
Practice practice practice. I have a 3 stall driveway that narrows down to 2 and has a nice angle on it back home. I stuck a 25' enclosed in the 3rd spot of the driveway with no problem. It was much trickier than it sounds.
Bottom line is that you just need practice. Whether it is a 4x8 utility trailer or that 25' enclosed I have no problem backing up trailers. I have had quite a bit of practice though. Go to a parking lot or something and just keep trying it.
There are some people who will always struggle with it though. Backing up a trailer comes naturally for some and is a struggle for others. Good luck!
Old Oct 4, 2007 | 10:06 AM
  #37
MisterCMK's Avatar
MisterCMK
4 low is nice if you are backing up an incline with a heavier trailer. It is easier to make small movements as you don't have to stress the motor as much.
Why anyone would pull the plug is beyond me. If I feel they are being a problem, I will turn off the brake controller, but it hasn't been an issue as I have a Prodigy.
Old Oct 4, 2007 | 10:07 AM
  #38
stormyrider
The main reaon for going to 4 low is to cut your ground speed while backing up, gives more time to react if things get complecated. I always recommend it for people new to towing for that reason. It is also handy for those of us with lots of experience when tring to back into a tight spot or a curved drive.
Old Oct 4, 2007 | 11:31 AM
  #39
grafekie's Avatar
grafekie
Why don't you just... slow down?
Don't make things complicated. Just turn down the gain on the trailer! Lights are very important... I've come close to rear ending folks who decided nobody needs trailer lights anyways, be it going forward OR backwards. I tow horses commercially with a half dozen different trailers and none requires 4 low or removing the plug. Only one requires turning down the gain, and that's the brand new one with sensitive (but very nice) brakes.
Old Oct 20, 2007 | 09:19 PM
  #40
conetractor's Avatar
conetractor
I take it that you dont drive a standard transmission. I use 4 low when backing up my 18 foot trailer so I can let the clutch out and back up slow and steady without slipping the clutch. The clutch will last alot longer!
Old Oct 20, 2007 | 09:36 PM
  #41
mudmaker's Avatar
mudmaker
have had both auto and 6spd. Under normal circumstances I have never used it, but to each his own.
Old Oct 20, 2007 | 09:42 PM
  #42
03PwrStk's Avatar
03PwrStk
6.0L heavy loader. left is right and right is left is true only if you are dealing with only one pivot point. If you have two then you steer in the same direction that you want to go. Just a tip from a truck driver.
Old Oct 21, 2007 | 07:43 PM
  #43
smokestone52's Avatar
smokestone52
Originally Posted by Ironhorse7
Next tip: Practice, like in a school parking lot. You might not realize it, but every time you do it you're training your mind, and after a while it will be again.
I tried that, and boy did I have a bunch of mad teachers, including my wife!!!
LOL. Hahahaha
But there are great suggestions here. For me putting my hand on the bottom of the steering wheel, and using the mirrors works great. And practice, a lot. In an EMPTY school parking lot!
Old Oct 22, 2007 | 08:13 AM
  #44
chrono4's Avatar
chrono4
then obviously you've never had to back a trailer that required going SLOW, or backed a truck with a numerically low gear set. Even in my f150 in reverse, its too fast to back my car trailer or any trailer for that matter for a long distance and requires slipping the clutch to keep the speed down. slipping clutch, especially when pulling a trailer = BAD
Old Oct 22, 2007 | 11:21 AM
  #45
grafekie's Avatar
grafekie
Can't say I've ever had that problem either. And I've backed big trailers long distances. Never had to drop into 4x4 unless I was in mud or slippery grass!
