86 suspected vaccum problem
Old Sep 28, 2007 | 07:42 AM
scottddove's Avatar
scottddove
Here is what is going on. When I am driving down the road and have the air conditioning on and come up on a hill (making engine work harder) the air that is blowing out the a/c vents goes away and will return after i get over the hill. I suspect I am losing vaccum or I just dont have enough. I have a 460 with all the smog stuff gone and I am getting vaccum from a port below the pcv valve at the passanger side valve cover. Is that a good location to be getting vaccum or should I be getting it from maybe the intake behind the carb. any ideas??
Old Sep 28, 2007 | 05:14 PM
Piffery1's Avatar
Piffery1
My truck did that and I found a crack in the vacuum resevoir on the bottom side where you couldn't see without removing it.
Old Sep 28, 2007 | 05:35 PM
Franklin2's Avatar
Franklin2
Yes, the vacuum line that goes into the passenger side of the firewall, should have a check valve and a tee with the vacuum can on it.
Old Sep 28, 2007 | 06:15 PM
scottddove's Avatar
scottddove
it has a check valve and the canaster you are speaking of. Is the vaccum source from the valve cover good enough or even the right source to be getting vaccum from?? I will hook up a guage and see if it will hold vaccum or should it hold it?? what kind of numbers should I test for??
Old Sep 28, 2007 | 09:17 PM
Piffery1's Avatar
Piffery1
On my '83 the vacuum source is an intake manifold fitting (at rear) with a line going to a Vacuum Distribution Block (VDB) which is essentially a "Tee". From the VDB a line to the Heat & A/C circuits (check valve, reservoir, control) and another to the automatic transmission (if so equipped) vacuum modulator. My PCV valve does not have a vacuum line. So, I'd connect the vacuum check valve such that manifold vacuum is directly applied.
Old Oct 1, 2007 | 02:57 PM
Bear River's Avatar
Bear River
Former ******
To some extent, this is normal function. However, anything that causes a drop in vacuum pressure can cause this problem. One possibility, is a clogged catalytic converter. The backpressure from a clogged cat will cause lower than normal vacuum. I'm not saying you should immediately jusp to the conclusion that a clogged cat is the problem. But it is a possible problem or contributor that should not be overlooked.
