Sponsored by: Real Truck
dual vs heavy
Old Sep 27, 2007 | 08:59 PM
Will 1997's Avatar
Will 1997
dual vs heavy
Pros an cons to the heavy duty alternator vs the dual?
Old Sep 27, 2007 | 09:28 PM
bnmccoy's Avatar
bnmccoy
Below is from the "Whats new for 2008" commercial order guide.
I have meant to see if the Job 2 with single alternator really have vacuum brakes as it seems the following indicates. Might be a reason to get dual alternator if you prefer the Hydro Boost.
Vacuum Brakes (Late Availability)
• Provided on all SRW diesel engine models,
except dual alternator installations.
• Dual alternator option continues to use Hydro
Boost brakes.
• Same system as used on SRW gasoline engine
models.
• Includes a vacuum pump on the front accessory
drive of the diesel engine.
• Hydro-Boost will be available as a limited production
option (LPO) with SRW for those who
require an open front accessory drive location.
Old Dec 19, 2007 | 09:31 PM
oltrucker's Avatar
oltrucker
there is a 200 amp alternater option, the dual is 325 amps.
Old Dec 21, 2007 | 09:17 AM
capn kirk's Avatar
capn kirk
think of it like twin engines on a boat. if one fails you still make it home
Old Dec 21, 2007 | 09:48 AM
BLK94F150's Avatar
BLK94F150
I'd definitely go with the twins. However, the 01 and 02 trucks I used to plow with only had the singles and we didn't have many problems with them. I burned an alternator one year, but that's not all that bad. I think that's the only one to go out.
These trucks had a pretty heavy electrical load to. Liftgates, strobes, and 8ft Western snowplows that got worked a lot. They are public works truck that plow the city streets.
Mike
Old Dec 21, 2007 | 11:11 AM
redford's Avatar
redford
FTE Leadership Emeritus
So, if you have dual alternators you can't have hydroboost brakes, you need vacuum brakes?
Old Dec 21, 2007 | 10:28 PM
oltrucker's Avatar
oltrucker
as far as i know, all diesels use the hydroboost brakes. alternaters are neally the most reliable thing on vehicles tody. in 47 years of big truck experience, i never lost an alternater in one of my trucks.
Old Dec 22, 2007 | 02:09 AM
blackhat620's Avatar
blackhat620
Just the opposite, PSD with dual alternators will continue to use Hydroboost brakes, PSD with single alternators will get Vacuum Boost brakes.
Old Dec 22, 2007 | 10:36 AM
redford's Avatar
redford
OK, thanks!
