What is a longblock?
Old Mar 8, 2002 | 02:31 PM
DutchmanAZ's Avatar
DutchmanAZ
or, more accurately stated, what should I expect to get when buying
a long block? What will I have to purchase separately?
Thanks!
Old Mar 8, 2002 | 03:19 PM
sturzinator's Avatar
sturzinator
A longblock is generally defined as a complete bottom end and the heads. Basically everything mechanical minus oil pan, valve covers, ignition, intake, carb.... you get the picture. I'm sure that some have a different perspective of this, but that's what I and everyone I know always referred to a "longblock" as.
Old Mar 8, 2002 | 04:41 PM
karlsd's Avatar
karlsd
Yup. A long block is a short block plus the heads and valvetrain. Many shops offer a long block with the "cam of your choice." Short blocks usually come with an oil pump, so the long block will, too. Long blocks may or may not come with a water pump, so ask the shop. You'll still need an intake manifold, carb, valve covers, oil pan, ignition system, cooling system (radiator, fan, etc.), flexplate or flywheel, etc.
Old Mar 9, 2002 | 10:35 AM
Sunny_in_hollister's Avatar
Sunny_in_hollister
