View Poll Results: cleaning turbo
ford
40.00%
turbo
60.00%
Voters: 5. You may not vote on this poll
Cleaning Turbo????????
Old Sep 27, 2007 | 05:47 PM
als4by4's Avatar
als4by4
Talking Cleaning Turbo????????
I took my truck in it has the 6.0 Diesel and is a 2004 F-250 they informed me that my Turbo neede to be cleaned....Can anyone help me out or is it something that has to be done at the dealership?
Old Sep 27, 2007 | 11:22 PM
blackhat620's Avatar
blackhat620
If your truck is still within the 5/100K warranty then it is covered by the Emissions warranty and the dealer will do it for no charge.
If you are outside of the warranty then you can do it yourself, here is the link on how to do it.
http://www.forddoctorsdts.com/articl...icle-06-05.php
Old Sep 28, 2007 | 10:22 AM
bpounds's Avatar
bpounds
Yea, what blackhat said. It might cost you $100 depending on your state and mileage. So while I might be able to do it, I would not do it to save $100.
No offense intended, after all this is your first post, but your poll is not very useful to the forum. Without knowing something about your mechanical skills and experience there is no way we can advise you on this.
Meanwhile, welcome to FTE.
Bill
Old Sep 28, 2007 | 08:54 PM
18vtx00's Avatar
18vtx00
[QUOTE=blackhat620]If your truck is still within the 5/100K warranty then it is covered by the Emissions warranty and the dealer will do it for no charge.
www.forddoctorsdts.com/articles/article-06-05.php[/QUOTE]
not exactly, it is covered by the 5/100k diesel waranty and over 3/36 will have a customer co-pay of $100. sometimes when we inspect them for cleaning they are to badly rusted and will require replacement.
Old Sep 29, 2007 | 02:24 AM
blackhat620
Well from page 13,14&19 of the Warranty manual, the turbo Charger is covered under the Emissions warranty, so the owner is Not supposed to pay for any items repaired that are covered by the Emissions warranty.
"WHAT IS COVERED?
These parts are covered by both the Emissions Defect Warranty and the
Emissions Performance Warranty.
List of Parts Covered by Emissions Warranties
• Air Flow Sensor
• Air/Fuel Feedback Control System and Sensors
• Air Induction System
• Altitude Compensation System
• Catalytic Converter
• Cold Start Enrichment System
• Cold Start Fuel Injector (1)
• Controls for Deceleration
• Electronic Ignition System
• Exhaust Pipe (Manifold to Catalyst)
• Electronic Engine Control Sensors and Switches
• Evaporative Emission Control System
• Exhaust Gas Recirculation (EGR) System
• Exhaust Heat Control Valve
• Exhaust Manifold
• Fuel Filler Cap and Neck Restrictor
• Fuel Injection System
• Fuel Injector Supply Manifold
• Fuel Sensor (1)
• Fuel Tank (non diesel only)
• Fuel Tank Pressure Control Valve (1)
• Idle Air Bypass Valve
• Ignition Coil and/or Control Module
• Intake Manifold
• Intercooler Assembly - Engine Charger
• Malfunction Indicator Lamp (MIL)/On-Board Diagnostic (OBD) System
• PCV System and Oil Filler Cap
• Powertrain Control Module
• Secondary Air Injection System
• Spark Control Components
• Spark Plugs and Ignition Wires
• Synchronizer Assembly
• Throttle Body Assembly (MFI)
Turbocharger Assembly• NVG module (Bi-fuel/CNG)
(1) Flex Fuel vehicle only
Important Information About List of Parts
Also covered by the two emissions warranties are all emissions-related
bulbs, hoses, clamps, brackets, tubes, gaskets, seals, belts, connectors,
non diesel fuel lines, and wiring harnesses that are used with components
on the list of parts, above."
http://www.motorcraftservice.com/pub.../04frdwa5e.pdf
On 2003 & 2004 MY SD the Emissions warranty for Non-CA emissions vehicles is 5/50K and for CA emissions vehicles it is 7/70K
Starting with the 2005 MY SD the emissions warranty for Non-CA emissions vehicles is 5/100K and for CA emissions vehicles it is 7/70K.
Any work that falls under the emissions warranty is done with No cost to the owner of the truck as outlined on page 7 of the warranty manual.
"NOTE: Some components may also be covered by the Emissions Warranties,
with no deductible. For more information, see pages 11-24."
Hope this helps clear up the confusion of what is covered under the Emissions warranty and for how long.
Old Sep 29, 2007 | 08:48 AM
wb6anp's Avatar
wb6anp
Does this note mean the emissions warranty HAS a deductible?
Old Sep 30, 2007 | 02:22 AM
blackhat620
No emissions warranties do Not have a deductible, the emissions warranties are governed by state & federal guidlines.
