Glow plug control unit-no start?
Old Sep 27, 2007 | 01:44 PM
BubbaBud's Avatar
BubbaBud
'91 7.3 F350 dually, '94 reman engine. Yesterday, I thought I had a fuel problem-today not so sure! O.K., I did a lamp test on each plug and found one dead, which I replaced. Today, I did the Haynes manual control unit tests: Ground o.k., supply voltage-o.k., ignition terminal to grnd-o.k., Lamp test off the test terminal produced no light, nada (which should come on for 7-15 seconds, based on temp). NAPA has a replacement for $200, thought I'd check here first. The truck had become harder and harder to start cold, once warmed up no problem. Last 2 days, I replaced the fuel pump (lift pump), filter. After that, no start. Charged batteries overnite, cranked several times-nothing, gave it a tiny shot of ether ( I hate to do that, but....), immediate start not a miss runs like a champ. I might add, this morning's second try, had wife turn on the ignition and I waited a little and thought I should feel some warmth/heat on the plugs, but they were stone cold! Got any ideas before I spend $200! Thanks, Bill
Old Sep 27, 2007 | 09:15 PM
michaelbrainardatwor's Avatar
Possibly, the manual glow plug switch conversion....Works like a charm for me.
Old Sep 27, 2007 | 09:20 PM
https://www.ford-trucks.com/forums/5...+manual+switch
Check out this thread
Old Sep 27, 2007 | 09:29 PM
PLC7.3's Avatar
PLC7.3
WTS light is operated by the WTS module and is on fuse #17 in the cab fuse box.. check the connection also....... You must have a VERY good ground on the engine for the controller.
Old Sep 27, 2007 | 09:50 PM
BubbaBud's Avatar
BubbaBud
Just goes to show, you don't need to know anything-just where to ask! Thanks!
