Sponsored by: Auxito
o2 sensor
Old Jun 9, 2002 | 11:26 AM
JOHNORF's Avatar
JOHNORF
Post o2 sensor
'97 4.2L, auto, 57000 miles
The check engine light came on. Took it to AUTOZONE for a free checkup. Error code was PO 133. Brought home a new O2 sensor. Lifted the hood and found two(2) sensors, one on the exhaust manifold and one on exhaust pipe. Question: are these two sensors the same or are they differant animals? Which one does PO 133 refer to? They guy at AUTOZONE was clueless. Thanks for any help.
Old Jun 9, 2002 | 08:19 PM
z 97ford1's Avatar
z 97ford1
Post o2 sensor
I have a 97 f150 4.6 with 112k miles it has 4 o2 sensors. At 100k I had an o2 sensor go bad and replaced all of them since they are inexpensive but, you could pull each one of yours out and clean it with "electrical motor cleaner" or pure gasoline and reuse them( I have done this before). The deal is that they get dirty with exhaust and can not detect the oxygen in the system.
Old Jun 10, 2002 | 11:55 AM
JOHNORF's Avatar
JOHNORF
o2 sensor
Additional info: The code PO133 refers to bank 1, sensor 1. Now my question is which side of the truck is bank 1?
Old Jun 10, 2002 | 06:46 PM
bosshoss's Avatar
bosshoss
o2 sensor
Dave Powell
Hey, how ya doing? Bank 1 is the drivers side. Bank two is the passangers side. Top sensor is number one. next inline is sensor number 2. Hope this helps. Dave
PS. Let the truck worm up before you try to change the sensors, but dont get burned. DO NOT LET THE COATING ON THE SENSOR THREDS DET ON THE SENSOR TIP.
Old Jun 10, 2002 | 09:46 PM
JOHNORF's Avatar
JOHNORF
o2 sensor
Thanks for the help.
Old Jun 11, 2002 | 12:14 AM
rkjerue's Avatar
rkjerue
o2 sensor
