More noise than I want
This is probably a stupid question, but I am curious if ther is a way to quite the noise in the cab after I installed a 4" exhaust turbo back system. It is a little louder than I would like and I havent even hooked it to the 5th wheel yet. Thanks for any advise.
01 lariat
01 lariat
Lots of folks ar einstalling a product called "B-quiet", which is a peel-and-stick product that comes in roll form. You have to remove seats, carpet/vinyl flooring, trim, door panels, roof liner, etc. Then you do the peel-n-stick install, using a small roller to make sure that it is securely pressed into the various curves and contours, and then re-install everything. The headliner in a Crew Cab, though, cannot come completely out without creasing it, so folks are just dropping it down and shifting its location around in the cab while working around it.
Do a search for "b-quiet", and you'll find several threads that talk about it. Everyone seems to find that it makes a big difference.
I got more drone than I bargained for when I put in my 5" exhuast. I love the sound at freeway speeds, but my wife always asks me to roll up the windows when we are driving on the surface streets and I like to listen to the Cannon. That wasn't part of the plan!
I'm working on something that will quiet it down, but it will be a while. Sort of a back burner project with all the rest of the duties that I have right now.
01 lariat
01 lariat
http://store.summitracing.com/partdetail.asp?autofilter=1&part=WLK%2D24217&N=700 +0&autoview=sku
Here are some thread links.... each one is a little different, and are not from the same thread even though the links below look identical.
https://www.ford-trucks.com/forums/6...t=bquiet+sound
https://www.ford-trucks.com/forums/5...t=bquiet+sound
https://www.ford-trucks.com/forums/4...t=bquiet+sound
We're about to start a two layer system. The first layer is a 8th inch layer of insulite and then the second layer is a butale / asphalt layer. I'll get the brands from my wife and or the link where she got the materials from and post it up. That is my weekend project in fact taking out the seats and putting in the sound proof and paint / dye the vinyl.
Mallo
Mallo
