Door Tag
Old Sep 26, 2007 | 09:46 PM
handsomerob's Avatar
handsomerob
Door Tag
O.k. Door Tag says Trany is a T = 4 speed auto
however the truck has the Overdrive position on the shifter.
Am I missing something here?
Old Sep 27, 2007 | 07:40 AM
kcb37's Avatar
kcb37
Is it a 4 speed or 5 speed? Some of the 4 speeds did have overdrive.
Old Sep 27, 2007 | 10:33 AM
handsomerob
wouldn't it list it as a 4 speed overdrive then?
handsomerob
Says that T is from a ranger not an F-150
Old Sep 27, 2007 | 10:41 AM
leegbee's Avatar
leegbee
My 95 F150 has a 4 spd auto with an overdrive, and T in the vin code. I've also seen an 86 F150 with a 4 spd auto with an overdrive. If its the original tranny, it should be an overdrive. Some of the newer ones, like my 95 have Ford overdrive embossed into the bottom of the tranny oil pan.
Old Sep 27, 2007 | 10:50 AM
Skandocious's Avatar
Skandocious
I don't believe that door sticker decoder in the articles above to be entirely accurate. It says the T code is from Rangers only but I think that is incorrect... A T code transmission should be an AOD or AODE, one of the two.
