Back around 2002 when I was nosing around the CB forums some of the guys
there spoke of really powerful CB's (with attachments) frying radios at red lights. They said you just had to be close and key up the CB. They seemed to know all of the right parts to put together for these little forays into the world of too much bass.
K, workin on the diamond...jewelers aint open, so we gotta plan the breakin. Somebody else gotta run out & get the duct tape, I don't have time. Meet back here when we get it all.
Several years ago someone, I don't recall who, sold a speaker system to cancel external noise. It was very large and expensive and worked along these lines:
I recall it was effective, but due to price it never took off. Most effective thing is to get double pain windows with heavy glass. It will help some. Next cover the walls with Sonex acoustical foam:
i dunno but what is getting to me is this jerk who has a motorcycle who runs down the block like 2am with wide open pipes.. but i suspect that one night maybe when he comes down a bunch of neighbors will throw a couple hundred ball bearings in the street that would cure him then we can work on the loud radios
You might go on findlaw.com and see if there are any codes concerning nuisance noise levels. If there are none, it might be time to attend some city or county government meetings. Also there is civil litigation, but that can be expensive.
Just be friendly like and ask the kid to show you his system.... when you are completeley blocking the subs so he cant see you , get in there take a small sewing needle and poke holes in the cones. you may have to endure a few more sessions of thumpa bump, but the holes will get larger and larger and the speaker fuzz will drive him batty.
OR
I've got a set of train horns you can borrow. 135db at 50ft...... but you must promise to use this new found power only for good
