Offroad & 4x4
lift question guys....
Old Sep 26, 2007 | 07:37 PM
trueb's Avatar
trueb
Question lift question guys....
ok I have a 96 f-250 x-cab diesel, all stock, I want to lift it 6" all suspension... my question is i bought the ttb drop brackets from a guy and the rear block kit too, I will need a pitman arm I THINK?? and front lifting leafs with u-bolts and bolt kit to install, my question is where would i go ( or does anyone know of) some for sale?? can buy the whole kit too. going the used route to save a little cash. is there anything else i need for this?? thanks
Old Sep 26, 2007 | 08:57 PM
blue beast's Avatar
blue beast
Extended brake lines get them now!! don't wait and try to reuse the stock ones!! Get braided stainless they will flex less under hard braking which could save your life!! You have bigger tires, taller truck you should have stronger brakes. empty the brake resovoir first then refill with fresh fluid, before bleeding that way fresh fluid is through out the system!
Old Sep 27, 2007 | 09:33 AM
trueb's Avatar
trueb
forgot to say i already picked some of those up, anything else on the lifting leafs or anything else i asked about. I appreciate it!
Old Sep 27, 2007 | 12:36 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
If you insist on using blocks (ugh...), whatever you do, DO NOT STACK THEM!!
Old Sep 27, 2007 | 12:43 PM
chrono4's Avatar
chrono4
One big thing with the stainless steel lines, is that alot, and I mean alot of them are not DOT approved, and for a reason. What happens with them, especially with offroad trucks and the like, is road grit gets into the braids of the ss, and wears away at the inner lining and makes short work of eating through them. The DOT approved ones are usually expensive, but its been a while since I looked at them.
Old Sep 27, 2007 | 01:58 PM
trueb's Avatar
trueb
of course not, never will stack the blocks.....and I do have the DOT lines, made sure of that. so I ordered the bolt kit from tuff country for the lift, I am still short the springs and shocks. is there anything else beside the springs and shocks I need that I havent already gotten, or does anyone have some FS?
Old Sep 27, 2007 | 02:27 PM
MBBFord's Avatar
MBBFord
Question: You have 6" blocks? IF so, just a warning, these will cause a LOT of axle wrap. I have 3" blocks and hate them(b/c of the axle wrap). Unless you plan on installing traction bars, it might be a good idea to try somthing else(add a leafs and shackle flip).
You'll need a drop pitman arm or adjustable drag link(most people prefer the drag link.
You have the extended brake lines.
Front springs... Either skyjacker or custom(I personally don't care for some of the other companys spring quality).
Shocks: Skyjacker or Rancho for a affordable quality shock. Doesn't need the be a RS900 either, the 5000s would do the trick.
Gears: Do you plan on regearing?
TIres: Curious, what size, and what will you use your truck for?
Old Sep 27, 2007 | 03:18 PM
stumpbuster's Avatar
stumpbuster
he would not need a 6" block if he is running a 6" suspension. the rear will always be a few inches shy of the front. he would need a 4" block.
Old Sep 27, 2007 | 03:24 PM
chrono4's Avatar
chrono4
regardless of whatever size block comes with the kit, his truck alread has a stock 3 (?) inch block in the rear.
Old Sep 27, 2007 | 04:02 PM
trueb's Avatar
trueb
Question
TIres: Curious, what size, and what will you use your truck for?[/QUOTE]
so just the adjustable drag link or pitman arm, the front leafs, and shocks is there anything else i need?? I have the bolt kit, blocks, and brakelines. going to re-gear a little later and and going to use 36" tires. trying to do this cheaper than the 1,200 kit ;-)
Old Sep 27, 2007 | 05:30 PM
chrono4's Avatar
chrono4
Do you have new pivot bushings? What about a good set of radius arm bushings? While you have it tore apart, make sure to check out all your ball joints, and u joints in the front end.
Old Sep 27, 2007 | 07:36 PM
MBBFord's Avatar
MBBFord
I was thinking about new bushings, but he doesn't have radius arms (F250).
I order to not do stacked blocks he would need something right around 6-7" for a perfect level truck(but a slightly higher rear is always a better thing, so he'd need even more if he got rid of the stock blocks).
Old Sep 27, 2007 | 08:25 PM
chrono4's Avatar
chrono4
dur, guess it was just a textbook response, wasnt even thinking.
Old Sep 27, 2007 | 08:28 PM
MBBFord's Avatar
MBBFord
I know what you mean, I was typing c bushing, radius arm drop brackets, etc...then I remember it was a F250.that changed my response
Old Sep 28, 2007 | 08:50 AM
quadzjr's Avatar
quadzjr
just another Rockwell looser
they gave me a 5.5" block for the rear...
