My thinking on the computer controlled engine is that: The engine can be lugged more because the timing can be precisely programmed. The fuel mixture can be tuned for economy at cruise, and power at W.O.T.
I am assuming here that you do not have to keep a cat. converter 'happy'.
Big cu. V8's get a bad rap because they are usually paired with either an:
auto trans. or 4WD or heavy vehicle or an aerodynamically inefficient vehicle (high ground clearance, wide bias ply tires, barn door front) or stump puller gears or heavy loads or lead foot or all of the above.
I can't blame any of these on the engine. True, Big cubes are less efficient when they are to big for the job.
My choice:
Small engine with lots of gears.
What about instead of a cummins out of a dodge truck, a 4bt? How expensive are those and would one give me enough power to pull that boat and still run at 70 down the interstate? How long do they last?
The cummins is a good engine. It requires at least a 3/4 ton to hold the weight. My son has got a 460intercepter/C6 in a 74 ranger and gets 18MPG on the freeway. High rear, and light truck.
well, the bronco weighs about 5500 lbs i think, so not light. The rear end is about middle of the road at 3.54 but the highway driving is only a small part of what i want it to do. But 18 is about double of what i usually here them getting and 13mpg is the most ive ever heard them get so that 18 is awesome.
