302 help
Old Sep 26, 2007 | 12:15 PM
95Ford4x4's Avatar
95Ford4x4
302 help
i just bought an 82 f150 with a later model 302 in it. problem i have is i need to buy a belt for the ac compressor and don't know the year of the motor. it has the serpentine belt system, but it's not one belt for everything. it has one belt going to the power steering, alt, water pump, and crank, then there's a separate one for the ac compressor to the crank, with an tension pulley between them. it is carbureted now, but don't know if that was converted or not. any ideas would help. i know i can pull the casting numbers, but was hoping someone might just know the years ford used this belt setup. thanks.
Old Sep 26, 2007 | 12:20 PM
cotawa's Avatar
cotawa
If you have the belt that's on it just measure that, or run a piece of string the way that the belt would go measure that and take into account some deflection for the tensioner.
Old Sep 26, 2007 | 12:45 PM
kcb37's Avatar
kcb37
Take the belt to the parts store with you.
Old Sep 26, 2007 | 02:01 PM
95Ford4x4's Avatar
95Ford4x4
doesn't have a belt on it, i've got to get one so I can diagnose the ac system and find out why the PO wasn't using it.
Old Sep 26, 2007 | 02:04 PM
cotawa's Avatar
cotawa
k fine, do the string trick I spoke about. It'll be quicker than trying to track the info down.
texasjack
24
Apr 10, 2021 10:10 AM
thejim42
27
Oct 31, 2013 06:53 AM
LeeLeadingham
Jul 30, 2011 10:29 PM
Wynn96
Sep 22, 2010 08:59 PM
