Need Help
Old Sep 26, 2007 | 11:55 AM
Cowboy34's Avatar
Cowboy34
Question Need Help
i have a 67 Ford F100 and i am needing a 9" rearend the one under my truck i have tried to get the yoke off to re[place the seal but the rearend has gotten really hott and cannot get the yoke off so i am looking for another 9" rearend and i have found one that is under a 82 Ford P/U and i need help desivering the axle codes i have here #WDM-W8JD 3018 350 9 80LB can any one help me PLEASE!!!
Old Sep 26, 2007 | 12:21 PM
Cowboy34's Avatar
Cowboy34
i gave the wrong code to the post that is the one thats in my 67 right now
Old Sep 28, 2007 | 10:10 AM
blue beast's Avatar
blue beast
Heat that puppy up with a torch and get a puller it should come off, If it's the original rear end keep it on there!! if all else fails you can cut it off very carefully and replace it. Just sawz all almost to the splines then put a wedge in there and hammer it it should tear that last bit of metal and not hit the splines if the wedge is steep enough!!
