#3 cylinder dead,...HELP!
Old Jan 11, 2002 | 12:40 AM
Ratsmoker's Avatar
Ratsmoker
Old Mar 28, 2002 | 06:53 PM
lee's Avatar
lee
It's a 390 in my 70 F-250 4x4. Did a compression check all average 135psi except #3. It is 15psi. Pulled the valve cover and had my son turn it over. Valves appear to be operating normaly. Only odd thing I found is that the exhaust push rod does not spin freely like the rest. I put my finger over the spark plug hole and get weak air flow during cranking. Head is a C8AE-H.
Also found some ground up material laying on the head. It is either hard plastic or brittle metal. I can break the pieces with my fingers. Wonder what it could be from?
Any ideas on what I should do next? On a side note I have owned the truck ~2 years and only put 2K miles on it. It runs OK oddly enough just has never had the power I thought it should have. Now I know why.
Thanks,
Lee
Old Mar 28, 2002 | 07:17 PM
BB's Avatar
BB
Maybe exhaust seat recession? Check the exhaust valve stem height, is it the same as the others? The ground-up material could be what’s left of those umbrella type valve stem seals.
Old Mar 29, 2002 | 11:56 AM
karlsd's Avatar
karlsd
At 15 psi, I'd suspect a burnt or broken piston. I think you need to pull the head, regardless.
