drivetrain swap
Old Sep 25, 2007 | 09:00 PM
jsarver11's Avatar
jsarver11
drivetrain swap
hi guys i was wondering if a 400M, 4-speed trans and transfer case out of a 1979 f250 will fit in a 1984 f250 and what it takes to make it happen. thanks
Old Sep 28, 2007 | 02:43 AM
Sycostang67's Avatar
Sycostang67
Kind of depends on what motor was originally in the 84'.
Old Sep 28, 2007 | 03:55 AM
greythorn3's Avatar
greythorn3
should be easy if it had a 460.. if not you will need to change your frame towers and engine mounts probably.
Ray
Welder and tapemeasure will make anything happen
Old Sep 28, 2007 | 08:35 AM
uh60's Avatar
uh60
I have an 85 F250 that some did that very same thing. But mine was an Auto before. They punched a hole in the fire wall for the clutch pedel linkage. But I have been converting it back to an auto. Form what I have taken apart it seems like it wouldn't be that hard. I am not sure what kind of motor the truck originally had. As long as you have the donor truck to get parts off of you should be ok.
Old Sep 28, 2007 | 03:27 PM
83stepside32784's Avatar
83stepside32784
i just did this swap last weekend, you do not have to change the frame mounts if you have a 302 or 351 the only problem i had was accelerator cable i had to make it longer, other than that its straight forward and can even use the 70s motor mounts,if you have any ? let me know
