Ignition Problem with 360
Old Mar 27, 2002 | 04:41 PM
Low56's Avatar
Low56
I have a 75 F 100 with a 360 2 barrel.
The truck will start cold and run fine but when you shut it down and let sit a few minutes it will not start back up.
I have checked and it is not getting any fire.
If you let it sit about 20-30 minutes it will start back up.
I have replaced the ingnition control module (Twice), the rotor button, distrbutor cap, plugs, wires, coil,and condensor.
I have not replaced the Stator yet but that is next on my list.
Any ideas?
I am going nuts over this one.
Thanks for any help you can offer,
Old Mar 27, 2002 | 06:40 PM
Pedal2metal's Avatar
Pedal2metal
Have you measured the voltage at the coil (12 Volts) when this happens?
Old Apr 1, 2002 | 08:27 PM
Low56's Avatar
Low56
Yes!!!
The Stator fixed the problem, I now have fire all of the time.
Thanks for the help.
Todd Morrison
Old Apr 2, 2002 | 12:38 PM
BB's Avatar
BB
These stators have a knack for opening up under temperature. A good test is to check for continuity while applying heat with a hair dryer. Glad you found it, sorry for the late post.
Yet another reason why I run a unilite and not a durafart.
Old Apr 2, 2002 | 03:15 PM
Low56's Avatar
Low56
