HELP electrical gremlins....
Old Sep 29, 2007 | 01:53 PM
BK50's Avatar
BK50
Okay riddle me this.... I put it all back together to start over, going to focus on the Y/W wire and eliminate it from the aquasion. Got it back together started it up nothing blowing???, turned everything on opened all the doors and lift gate still fine???.... Thought i'd try the pos+ on the neg- off use the test light again power everywhere???, diconnected it put the neg- cable back on still nothing???.... Took the X out for a drive, lights on and all; still nothing??? Came home repeated the above still the same???.... Decided to leave it run for an extra half an hour in the drive wiggling all the wires still okay nothing blown???.... Did my Gremlin die???, I dought it.... I'm going to drive it around this weekend and then we'll see hope it was just alt #1 (original) & #2 (reman) but my luck, there is no such thing.... I'll keep you informed....
Bill
Old Sep 29, 2007 | 02:05 PM
fordchick47454's Avatar
fordchick47454
afraid we might have the same gremlin lol
Old Sep 29, 2007 | 02:17 PM
BK50's Avatar
BK50
Not good.... What year is yours?
Bill
Old Sep 29, 2007 | 05:35 PM
fordchick47454
2003 blowing fuse 17 as soon as its replaced
Old Oct 1, 2007 | 10:15 AM
Larryconley's Avatar
Larryconley
check you main possitive wires that run to the starter and the starter soliniod
you have to have a bear part shorting against the frame somewhere. pull the solinoid off and check it for damage follow the wires to the alt and look for damaged insulation I know its a pain in the @ss Good luck
dunwannotrouble
Jun 17, 2018 09:09 PM
remadl700
Modular V10 (6.8l)
Aug 17, 2011 06:20 PM
abigjeep
Electrical Systems/Wiring
Apr 9, 2009 09:51 PM
BK50
Sep 27, 2007 09:39 AM
