Sponsored by: Auxito
blower motor problem
Old Sep 24, 2007 | 07:45 PM
gerdes's Avatar
gerdes
I have a 2001 f150 that is not blowing enough air through the air vents even if the fan is on high. I think there must be a restriction but don't where to begin looking.
Old Sep 24, 2007 | 08:06 PM
projectSHO89's Avatar
projectSHO89
Pull the blower out and inspect the evaporator for dust/dirt buildup.
Steve
Old Sep 24, 2007 | 08:07 PM
RanDogg's Avatar
RanDogg
Try checking the in cab air filter if it is equipped with one.
Old Sep 24, 2007 | 08:29 PM
lonerangerinaz's Avatar
lonerangerinaz
gerdes you might have a vacuum leak. If you have a small leak your vent door will not open completely which will keep some of the air from reaching the vents. Check to see if when the fan is on high you can feel some air coming out from the vents on top of the dash.
