Snow Plow
Old Sep 24, 2007 | 04:03 PM
eatfish's Avatar
eatfish
Snow Plow
Anyone had any luck running a plow on an Ex?
Old Sep 25, 2007 | 01:15 AM
RACERX7775's Avatar
RACERX7775
there is a guy with one on his X. all i can remember is that it was a red X.
Old Sep 25, 2007 | 12:44 PM
R.Dee1275's Avatar
R.Dee1275
I am running a boss 8'2" v plow on my 04 excursion with a 6.0 It plows great and has zero issues what so ever. I did get springs for the front just to make sure it handled the weight right.
Old Sep 25, 2007 | 01:17 PM
i eat hybrids's Avatar
i eat hybrids
R dee, how does it plow in 2wd?
Old Sep 25, 2007 | 01:34 PM
eatfish's Avatar
eatfish
No issues with airbag sensors?
Old Sep 26, 2007 | 12:04 AM
R.Dee1275's Avatar
R.Dee1275
Honestly two wheel drive is so so but I do not have a limited slip rear end. In four wheel drive its an animal and will move anything. No it has no issues what so ever with the airbag sensors. It is the same as a superduty as far as mounts go. You need to remove the blocker bar but it gets replaced by the plow frame. Thats the process with any plow install on a ford truck.
Old Sep 26, 2007 | 09:21 AM
i eat hybrids
The only reason why i ask, is because Downriver thunder (i think that is his user name) has a plow on his x and he said that he always plows in 2wd unless its over like 6 inchs. I was thinking about getting a plow, and putting a locker or a limited slip in the rear end with some commercial rated snow tires from BFG. I would obivously have to put sand bags in the truck. Do u think this is a dumb idea?
Old Sep 26, 2007 | 11:18 AM
eatfish's Avatar
eatfish
Depends on what you plan on plowing. Just a normal driveway (100 yrds or less) wouldn't take much to plow. You could always chain up and push about any amount of snow nature could throw at you in 2wd. It would be a hassle if you were planning on doing it commercially though.
Old Sep 26, 2007 | 12:41 PM
i eat hybrids
ur right. thanks for the tip
Old Oct 1, 2007 | 01:33 PM
reinforcer's Avatar
reinforcer
Please correct me if I"m wrong! I thought you couldn't put a plow on a diesel excursion? I took my truck to the local plow shop and they told me the diesel engine was so heavy that with a passenger(s) in the truck, the addition of a plow would overload the front axles capacity. They wouldn't even entertain the though of putting it on anyway, due to the liability exposure.
Old Oct 1, 2007 | 04:19 PM
i eat hybrids
Get new springs then go back. Or u can ask them about putting new springs on. If that doesnt work go to a different shop and see what they say
Old Oct 1, 2007 | 06:28 PM
weekendwarriorfsw32's Avatar
weekendwarriorfsw32
Master of Strokes
I think thats bs man,
Nick
Old Oct 1, 2007 | 08:44 PM
mudmaker's Avatar
mudmaker
Last friday I stopped by a local dealer for Boss plows and discussed different issues with plows and they told me the X would not be a problem at all.
Old Oct 1, 2007 | 08:47 PM
weekendwarriorfsw32
Master of Strokes
Thats what I would have thought,
Nick
Old Oct 1, 2007 | 11:38 PM
6.0 PSD 4x4 VAN's Avatar
6.0 PSD 4x4 VAN
IMHO, if it's not a 4x4 X "Don't Bother". To me, there is NOTHING MORE EMBARRASING than getting stuck wearing a PLOW! Trust me I know and I was driving a 4x4 Jeep! (Thank goodness I wasn't "Chained-Up" at that time!)
FYI, BFG Does NOT make a "Commercial Rated" (E-Range 3000 -3400 lb) Dedicated Snow Tire for an X. The only two 265/75/16 E Range real snow tires I could find are Bridgestone W965 (No Studs) or Cooper Discoverer (Studs OK) M+S. Nokian Hakkapelliita LT (Studs OK) are fantastic and I've used-up three sets on other vehicles, but are only available in D-Range in this size.
FYI I don't sell tires, I just wear them out!
Save the $ for a plow and trade-in for a 4x4 6.0 "X".
Just my $.02
Cheers,
Scott
'05 6.0 Excursion EB 4x4. Innovative Diesel Tuner, Turbo-Back Magnaflow, Intake Elbow, AFE Intake, Quadzilla Recon Gauges, Landyot Radius Rods etc. Winter Ski, Summer tow boat and 10K lb Racecar Trailer.
