throttle body Question..
Old Sep 24, 2007 | 02:23 PM
quisp-n-quake's Avatar
quisp-n-quake
88 5.0 EFI : I noticed that the throttle body has a coolant channel running through it, from top to bottom, does this coolant channel work with the IAC and TPS? - I mean as far as the coolant getting heated up to operating temp and the electrical components working off of the heated coolant?
Old Sep 24, 2007 | 02:53 PM
StealthWyvern's Avatar
StealthWyvern
I don't know but I currently have mine bypassed due to it leaking from one of the ports and I can't tell any difference in the truck other then its not using antifreeze anymore. I have a 94 302 atx
Old Sep 24, 2007 | 04:27 PM
EPNCSU2006's Avatar
EPNCSU2006
The coolant just keeps the throttles from icing and sticking open in cold weather. The IAC and TPS operate the same regardless of coolant temperature.
Old Sep 24, 2007 | 04:57 PM
StealthWyvern
Thanks! I forgot all about that but then again in im Florida so I dont have to worry about the butterflies in the throttle body getting iced open.
Old Sep 24, 2007 | 06:02 PM
quisp-n-quake
re: throttle que..
that sounds like common sense..Thanx.
