A few problems
Now for the problems:
-The truck was having some issue I attributed to the carb, it would idle very rough and then eventually idle down suddenly to about 600 and die until it was warmed up. I had the idle screw set so that it would idle at around 1k. Then, on my way home from work, it would just idle down and die immediatley, once i finally got home i figured out the the choke stayed open all the time as if it didn't have a rebound spring neccessary. The only thing is, even when i keep the truck reved up for a few minutes it still idles down and dies. Any ideas?
-The second problem is the play in the steering, it was terrible at first but I found that I didn't tighten the bolt down that connects the pitman arm to the tie rod fully. It looks as thought there is still play in the ball joint at that location, what tools do I need and what pieces should I replace? Do you think a steering dampener would be a good investment also? the truck floats alot even at slow speeds
I think thats all for now, i'll post pics if you need them thanks for any input
All of the joint pieces in the steering are available from the parts store. If you have a bad joint, then replace it. You buy the whole piece. Just be warned your alignment may be thrown out unless you are very careful when you replace the tie rod.
I would not buy a steering damper, unless you want to look cool. Get it driving correctly first, then buy the steering damper for looks, it's not needed on a properly repaired and aligned frontend.
EDIT: The top of the tank isn't rotted out I pulled the tank off when I painted the frame, but I didn't replace fuel lines, only brake lines which I kind of regret.
